June 2, 2015, 12:37 |
How to see trajectory of a bubble?
matias
Rep Power: 10 |
Hi everyone
I simulated air bubble in water 3D, I used VOF model, air velocity inlet, and pressure outlet, also other things. i want to see trajectory of bubble, how I can do it? I think that i have few options. -Track particle, I have read about it, but I havent learnt enough to do it, if this is the right way to do it, can you help me? -animate, my problem with this, is that I have a 3D model and I see volume of fraction, so the water not allow me see the bubble, maybe there is a way to see only the air phase and contour.?? -I used pathline, but this only show the trajectory of a non-mass particle at current timestep (i have understanding), i want to see trajectory of a bubble in a period of time (since formation until bubble arrive at free surface) someone can help me?? maybe exist another way? best regards |
March 4, 2018, 08:40 |
Diksha Agarwal
Did you get the solution to this problem? If yes, could you please help me? I am having the same doubt.
March 5, 2018, 05:38 |
Cees Haringa
Getting the trajectory in FLUENT directly is not possible - if you have a single bubble, however, it's relatively straightforward to get the center of mass. You can do that using a UDF that computes the center of mass from the phase-fields, and stores the coordinates in (for example) a text file that you can open in excel, matlab or another program of your liking. Alternatively, store the phase-field every timestep (or X timesteps) and get the center of mass in post-processing, such as MATLAB.
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 19, 2014 23:42 |
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? | EnronZhang | STAR-CCM+ | 1 | December 19, 2013 08:41 |
[ANSYS Meshing] Bubble modelling to simulate shape oscillations | akash | ANSYS Meshing & Geometry | 5 | February 1, 2013 01:32 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 00:02 |
