July 19, 2011, 17:05 |
mesh refinement
Ghazlani M. Ali
Rep Power: 28 |
I have to refine a mesh using the adapt command on a distant cluster.
the command mark-inout-sphere works very good, but the cluster stops responding like it's taking so much time to process. After i decide that may be the number of node is very big for it, i reduce the region to adapt and again the adaptation works, i can iterate , but when it comes to saving the data file, its stops again or sometime its stops iterating like it's taking so much time. I can know that is not normal because the cluster is powerful and cannot take so much time like that !! here is a example of where it blocks: 8 Stored Partitions: ---------------------------------------------------------------------- Collective Partition Statistics: Minimum Maximum Total ---------------------------------------------------------------------- Cell count 846096 846105 6768806 Mean cell count deviation -0.0% 0.0% Partition boundary cell count 5530 24576 136130 Partition boundary cell count ratio 0.7% 2.9% 2.0% Face count 2458746 2580047 20033170 Mean face count deviation -2.3% 2.5% Partition boundary face count 6457 40517 104559 Partition boundary face count ratio 0.3% 1.6% 0.5% Cell weights 8e+05 8e+05 7e+06 Mean cell weight deviation -0.0% 0.0% Partition neighbor count 1 4 ---------------------------------------------------------------------- Partition Method Principal Axes Stored Partition Count 8 Done. After Done. it doesn't respond anymore. does anybody had a similar problem ? Thanks in advance |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[snappyHexMesh] non-smooth mesh | Svensson | OpenFOAM Meshing & Mesh Conversion | 11 | January 18, 2012 10:13 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
Mesh refinement and the errors. | Korsh Mik | CFX | 0 | January 11, 2006 08:07 |
