August 29, 2003, 05:36 |
strange error
Did anybody ever see the error; Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION). Error Object: () Error encountered in critical code section Error: Unknown object encountered in garbage collection Error Object: #[unknown type 14592] Error encountered in critical code section Hit return to exit. you see the same error message as you hit the enter key. Closing cross at the corner does not work either. it is weird since it is an unknown type of error for Fluent also. regards emre |
August 29, 2003, 10:20 |
Re: strange error
Hi, I met this error in last two weeks at my university. My reason is virus attacked the internet or somewhere else in your computer.When the internet doesn't work, Fluent gave the error as you said.I hope this could give you a hint.
September 1, 2003, 08:35 |
Re: strange error
If you are using udf/adjust function which need some proper initialization of some values then fluent may give this type of error I don't think it is because of any virus. Could U describe your problem. Rahul
September 1, 2003, 08:52 |
Re: strange error
There is no udf. It may really be originating due to a virus, since the performance of the computer is creeping. i will scan it.
regards emre |
July 20, 2011, 19:17 |
fluent error please help
anish kumar
Rep Power: 14 |
Loading "C:\Users\anishks2/.cxlayout"
Done. > Reading "C:\Users\anishks2\Desktop\dissertation\icem cfd\ANISH\final 2 viola\fluentcase3.msh"... 16184 nodes. 15900 quadrilateral cells, zone 11. 31515 2D interior faces, zone 12. 480 2D wall faces, zone 13. Building... grid, Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () i m getting an error from fluent like this can somebody help me |
Display Modes | |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
nonNewtonian viscosity model | mhassani | OpenFOAM Programming & Development | 5 | January 7, 2013 09:27 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
