Stops responding after adaptation command!
Old   July 26, 2011, 21:52
Default Stops responding after adaptation command!
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
hello,
i've been doing some calculation on a remote cluster recently everything works fine. But when i decided to refine the mesh using the region adaptation command. Fluent stops responding after partitionning the grid , i don't really know if it's because of fluent or the cluster. i'm sure that it doesn't stop responding because it needs more time. It's just 20000 cell. Does somebody experience the same thing ? here's a screenshot of where it stops:
8 Stored Partitions:
Collective Partition Statistics: Minimum Maximum Total
Cell count 846096 846105 6768806
Mean cell count deviation -0.0% 0.0%
Partition boundary cell count 5530 24576 136130
Partition boundary cell count ratio 0.7% 2.9% 2.0%
Face count 2458746 2580047 20033170
Mean face count deviation -2.3% 2.5%
Partition boundary face count 6457 40517 104559
Partition boundary face count ratio 0.3% 1.6% 0.5%
Cell weights 8e+05 8e+05 7e+06
Mean cell weight deviation -0.0% 0.0%
Partition neighbor count 1 4
Partition Method Principal Axes
Stored Partition Count 8
Done.
After Done. it doesn't respond anymore. does anybody had a similar problem ?
Thanks in advance
diamondx is offline   Reply With Quote
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
