Access_violation Errors when using the macros C_T_G(c,t) in FLUENT UDF |
August 1, 2011, 13:52 |
I am using FLUENT 6.3.26 on a Windows 64 bit machine with XP installed. I am writing UDF source files in Visual Studio 2008 on the same computer. If I use the following code without line [*] (i.e. just set grad_f = 0.0 or something), then the code will generally initialise and iterate fine. (Using interpreted UDFs for now). #include "udf.h" #include "mem.h" #define K_MEMB 0.6 #define K_F 0.0242 #define T_o 310.66 #define DELTA_MEMB 0.001 DEFINE_PROFILE(heat_flux, thread, position) { face_t f; cell_t c; /*Local variables*/ real T_s, grad_f, q_f, q_memb, q_use; real NV_VEC(A); begin_f_loop(f, thread) { /*Find the relavant cell to current face*/ c = F_C0(f,thread); /*Find the face temperature*/ T_s = F_T(f,thread); /*Find the face area vector*/ F_AREA(A,f,thread); /*Find the temperature gradient in the face normal direction*/ [*] grad_f = (C_T_G(c,thread)[0])*A[0] + (C_T_G(c,thread)[1])*A[1] + (C_T_G(c,thread)[2])*A[2]; /*Find the heat flux*/ q_f = -K_F*grad_f; /*Apply this value to the boundary*/ F_PROFILE(f, thread, position) = q_f; } end_f_loop(f, thread) } When the problem is either initialised or iterations are begun (it differs from time to time), the following error pops up: Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () And just cannot get it to work. It will work provided there is no mention of C_T_G(c,t). (it works with A[0], A[1] and A[2]). I have tried typing solve/set/expert into the command window and selecting yes to "keep tempory memory from being freed?", to no avail. Any help would be very appreciated! Last edited by SuperNova79; August 4, 2011 at 08:48. |
Display Modes | |
accessing solver data with UDF macros | Dushan | FLUENT | 1 | April 22, 2017 21:05 |
Fluent UDF Discontinuous Motion | lequi7 | Fluent UDF and Scheme Programming | 2 | November 3, 2011 23:18 |
UDF in Fluent | subha_meter | Main CFD Forum | 0 | October 17, 2009 23:54 |
Compiling UDF in Fluent 12 | jsm | FLUENT | 1 | July 22, 2009 07:40 |
UDF of Zimont model in fluent | Z | Main CFD Forum | 0 | February 17, 2005 03:07 |
