June 16, 2004, 21:59 |
Air flow in hard disk drives
Dear Friends,
I am about to start researching the turbulent air flow characteristics in a hard disk drive using Fluent. In this connection I invite advices and suggestions on the turbulent model to be used here. Also let me know if there exists any literature that provides validation for numerical studies conducted on this problem. Cheers Sundar |
June 24, 2004, 05:16 |
Re: Air flow in hard disk drives
There are many papers in ASME J.tribology.about the air flow in hard disk. The thickness between magnetic head and rotating disk is extro-thin air film ( several nm order). A 2D generalized air lubrication equation is used to study this kind of problems . You may refer these papers.
August 10, 2011, 04:18 |
#3 | |
$hri
problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 09:36 |
UDF, air flow through a cell----get velocity in | lig | FLUENT | 0 | September 6, 2010 13:02 |
Air flow on a pipe | gulbenkian | FLUENT | 1 | June 8, 2010 07:31 |
Air flow over a cylinder | momentum_waves | Main CFD Forum | 1 | November 17, 2008 20:54 |
Hot rod in transverse air flow | Anders Larsson | Main CFD Forum | 3 | April 19, 1999 09:28 |
