August 17, 2011, 12:01 |
Impact temperature on an aircraft
Charles
I would like to simulate the temperature of the surface of a flying aircraft. The main point of interest is the impact temperature on the leading edges to determine icing datas. I didn't succeed in modeling it with Fluent. I used different models (Laminar, Spalart Allmart, k-Espilon) with a coupled solver but I get unsatisfying results. The thing is quite disturbing because after like 20 iterations I get a result that looks pretty good with a higher temperature on the leading edges. But when I iterate more the aircraft surface temperature become constant except for some small hot and randomly located zones. I activated the viscous heating, and I set the wall and the external temperature at the same value (240 K). The flow speed is 180 m/s and the air density 0.5 kg/m3. What would you do to solve such a case in terms of model, boundary settings....? There is no tutorial that is about the impact temperature. |
August 17, 2011, 18:44 |
Charles
I made some extra tests on a simple cube but I get divergent results after 200 iterations, no matter which solver I chose.
Do somebody have some pieces of advice to share about this viscous heating on a wall ? |
August 18, 2011, 12:01 |
Charles
My test on the cube finally succeed with the Coupled k-epsilon solver.
Still, when I try it on the real geometry, I get the message "Time step reduced for xx cells" after like 200 iterations, and the residuals are diverging a few iterations later... I read that it's due of sudden changes of temperature between iterations and that it could be caused by wrong solver setup... Can someone help me out ? |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Bulk temperature Tf is obtained from total or static temperature? | NPU_conanxie | FLUENT | 0 | March 30, 2011 05:56 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
