VOF Coefficient in freesurface cells
Old   August 12, 2011, 03:12
Default VOF Coefficient in freesurface cells
mj
mrji8011 is on a distinguished road
Dear Friends
I am simulating 2 phases (liquid-gas), 3D flow around ship and I want to capture wave height in far way. If I choose 0.1 as VOF for interface cells, my results would be match with experimental, while if I use cells with VOF=0.5 for freesurface, results are not accurate. I would appreciate if anyone send or introduce a reference which show I can use 0.1 for freesurface or not.
mrji8011 is offline   Reply With Quote
Old   August 12, 2011, 14:13
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Originally Posted by mrji8011 View Post
Dear Friends
definitly not,
to me it seems like a numerical diffusion problem. can you say in how many cells do you have the transition from vof 0 to 1? can you specify the model that you are using (implicit/explicit, transient or steady steate, wich solver, discretization order, wich vof reconstruction method, etc...)
sail is offline   Reply With Quote
Old   August 13, 2011, 21:50
mj
Originally Posted by sail View Post
definitly not,
Thak you so much. the number of cells depend on vessel speed. roughly it is 3 cells. I am using implicit, transient,Gradient=Least Squares Based, Presuure= Presto, Momentun=Second order upwind, volume fration=Quick and second order implicit for transient formulation
Old   August 18, 2011, 01:59
Question
mj
do you think it is correct or not?
Old   August 18, 2011, 04:50
sail's Avatar
Vieri Abolaffio
looks right.
do you have experiemental data for the whole wake field or just where it touches the hull? if the latter is your case, could you please post a plot of the vof close to the hull, showing the mesh as well?
i would like to check if the problem is just a sort of "numerical surfacial tension" ie high aspect ratio cell causes the flow to rise more that it is expected in the fist cell near the hull.
Old   August 18, 2011, 23:08
mj
looks right.
Thanks for replying
Please find the attacheds. I should capture waves in all domain.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
