July 27, 2011, 10:57 |
HELP . . . Vertical motion of a wing
Rep Power: 14 |
I am trying to model vertical movement of an airfoil.
I currently have a mesh which works well for normal flows over it but I am trying to look at the effects of vertical oscillations on the forces of the airfoil. My problem is that I cannot work out how to get my airfoil to translate. Thanks Phil |
July 29, 2011, 05:15 |
Adrien Lemoine
Rep Power: 14 |
Hey,
to translate your mesh you have to use a dynamic mesh (DEFINE_CG_MOTION). You can find some stuff about it in the UDF manual. If you have any questions ... bye
------------------------------------------- Plz add reputation if the answer is correct A cœur vaillant rien d'impossible ------------------------------------------ |
August 26, 2011, 06:45 |
Rep Power: 14 |
Hi again, I have had to take some time away from this project but now have some more time to spend on it, I have managed to write a udf though seem to have some issues with it.
I get the following warning come up when I apply my UDF to my airfoil. "Warning: incorrect cg motion UDF FOILMOTION on zone 7 (assuming no motion)" The UDF I am using is bellow #include <udf.h> DEFINE_CG_MOTION(FOILMOTION, DT, VEL, OMEGA, TIME, DTIME) { VEL[1]=sin(CURRENT_TIME) } Do you have any idea what could be wrong? Thanks |
airfoil, dynamic, movement, translation, wing |
3D Wing Analysis | Ed | FLUENT | 5 | April 13, 2019 13:07 |
Flapping Wing motion | balkrishna | FLUENT | 19 | April 13, 2016 15:42 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
