October 7, 2011, 03:57 |
Use data from multiphase into DO radiation
Rep Power: 14 |
Hi all,
I am modelling multiphase flow in a vessel and the results that I obtain (volume fraction of solids) will be used in the DO radiation model in Fluent to model the radiation intensity within the vessel. The 2 models (Euerian multiphase and DO radiation) cannot be used at the same time so I have to perform each of them independently. The volume fractions values (for each cell) that I obtained in my Eulerian multiphase model need to be used as a materials property input (absorption/scattering coefficient will be a function of volume fraction of solids) for my DO radiation model. My question is: how do I export those volume fraction results (for each cell) that I obtained in my multiphase model and use them as an input to the materials property in my radiation model? I hope that I have defined my problem properly. Thanks for your help, Yashmash |
【Help】"Error: Update_Time_Level: invalid data" | Chen | FLUENT | 2 | August 24, 2014 07:51 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
matching variable data with grid point data | anfho | OpenFOAM Programming & Development | 0 | May 6, 2011 15:28 |
Surface incident radiation | Pipiola | FLUENT | 0 | August 11, 2009 15:46 |
DO radiation model | jarno brunetti | FLUENT | 0 | January 21, 2006 15:52 |
