October 1, 2011, 05:23 |
Porous Model for distributor
Flavio
Rep Power: 15 |
I'm working on a distributor of a boiler: it should distribute the mix air+gas from the fan the to the heat exchanger (after have gone through a certain circuit). Since the distributor is a very dense metallic web (1 mm thick), I prefer use porous model (to avoid a mesh too heavy). I think that in this case it's better the Porous Zone rather than Porous jump because the distributor isn't plane but a little curved and the flow (turbolent) isn't perpendicular to it. Am I right? Above all I need some advice to define Inertial & Viscous Resistances: is possible to calculate them without experiments? From Fluent Manual I haven't found a good help (sometimes only C2 is calculated,ecc...) Please help me (excuse me for my horrible english) |
porous filtration membrane area in model | catherina | CFX | 3 | October 27, 2011 06:05 |
CFX Model for dispersion of gas through a porous media filled with Oil | deepmetal | CFX | 13 | November 27, 2010 20:34 |
Convergence of the porous medium model | fpingqian | FLUENT | 0 | January 8, 2008 22:54 |
How to use radiation model with porous model? | jacky | CFX | 0 | December 17, 2002 22:51 |
