Using a macro to write a plot to a file, and supress the popups
Old   October 3, 2011, 07:43
Default Using a macro to write a plot to a file, and supress the popups
Steven van Haren
stevenvanharen is on a distinguished road
Hi everybody,
I use a macro to write a line plot every 100 iterations.
This works fine, but I also get a pop-up every 100 iterations on my screen.
Can I suppress the fact that the macro creates these pop-ups? Or can I write this line plot to a file in a different way?
Thanks for your help!
Regards,
Steven
stevenvanharen is offline   Reply With Quote
Old   October 3, 2011, 20:44
Jack cosby
3DmaniacSLDWRKS is on a distinguished road
please explain what you mean when you say line plot????
and also what sort of pop up????
if by pop-up you mean the overwrite message you can suppress that by typing
file confirm-overwrite no in the TUI
hope that helps
3DmaniacSLDWRKS is offline   Reply With Quote
Old   October 4, 2011, 02:37
Steven van Haren
hope that helps
I create a line plot by selelecting plot --> XY plot. I select a line as a surface and click the 'write to file' option to write the XY data to a file.
I record all these steps in a macro (solve --> execute commands), and then execute this macro every 1000 iterations. However this macro will open the XY plot window and write file window. This is what I mean when I refer to popups.
These popups I would like to supress.
Old   October 4, 2011, 05:42
Amir's Avatar
Amir
Amir is on a distinguished road
Dear steven,
If you use journal file instead of macro, these pop-ups will be suppressed.
Bests,
Amir
Amir is offline   Reply With Quote
Old   October 4, 2011, 05:55
Steven van Haren
Dear Amir,
Thanks for your tip. I will try it with a journal file.
Regards,
Steven
Old   October 4, 2011, 08:15
Steven van Haren
I solved it using:
http://www.cfd-online.com/Forums/flu...tml#post133019
If I put these TUI commands in a macro I have no more annoying pop-ups!
Thanks for staying tuned
