May 17, 2004, 21:01 |
Gambit problem..
Hey everyone..
I have a question about Gambit. I've met an undefined error in gambit and it automatically terminated. After that, I can not start gambit again. It automatically generates error message like "/ File opened for write Mon May 17 20:50:27 2004. ERROR: IDENTIFIER "default_id" CURRENTLY OPEN" Do you guys have any idea about this problem? Should I re-install gambit? Thanks in advance |
May 18, 2004, 01:20 |
Re: Gambit problem..
you can start Gambit with this method: click (START) then (RUN)and write:
d:\fluent.inc\ntbin\ntx86\gambit.exe name this is the path that gambit is installed.every time that you run the program ,use different words instead of (name). some thing else;you must completely exit the program at the end. Soody. |
May 18, 2004, 03:37 |
Jay, look in your working directory for a tiny file with .lok extension. When gambit terminates ubnormally, it leaves this file and a temporary working directory behind. Just delete them and you'll be able to run it again. (The file is just a marker of an open session.)
Bye George |
May 18, 2004, 10:38 |
Thanks a lot, George It works. Perfect !!!
October 8, 2011, 04:15 |
Gambit Problem
Mohit
Hi
I want to mesh a 3D tube in Gambit, but in a volume mesh it writes this ERROR:'' Edge edge.2 and edge.4 are taken as the defult periodic edges for intervals control for face face.2 ''. Cuold you help me? |
October 10, 2011, 01:10 |
Maxime Perelli
Rep Power: 41 |
did you mesh something prior to the volume?
post a picture
In memory of my friend Hervé: CFD engineer & freerider |
Gambit geometry problem | cestrin | FLUENT | 3 | July 4, 2012 02:33 |
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam | Rachid BANNARI (Bannari) | OpenFOAM Meshing & Mesh Conversion | 25 | September 11, 2011 07:58 |
Gambit installation problem | Panos | FLUENT | 4 | March 5, 2009 22:44 |
Problem meshing with Gambit | Adrian | FLUENT | 8 | October 7, 2008 08:39 |
Startup Problem in Gambit 2.2 with WindowXP | Win Win Maw | FLUENT | 3 | January 25, 2006 11:09 |
