rotating plate
Old   October 11, 2011, 12:04
Default rotating plate
AlexAlex is on a distinguished road
I am getting ready to work on a 2D thin plate oscillating (pitch) about its CG (small omega and small angles) in infinite fluid (no free-surface) problem.
I have two questions:
-Is symmetry assumption (about the vertical axis through CG) valid? A previous study was for parallel oscillations (heave) and symmetry was good.
-Dynamic meshing is to be used. Is there a built-in UDF in ANSYS-Fluent 13 that can be used to model the motion of the body so dynamic meshing is to be implemented.
I am new to Dynamic meshing so any suggestions are appreciated.
Alex
AlexAlex is offline   Reply With Quote
oscillating 2dplate, rotational vibration
Rotating plate. farrr CFX 7 July 20, 2015 14:24
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 08:53
vibration of a rotating plate in water zhm Main CFD Forum 0 March 2, 2010 18:50
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 15:15
jet on rotating plate A.TOUZANI Main CFD Forum 0 January 30, 2003 10:05
