October 17, 2011, 09:00 |
hydroacoustical analysis
sabra
Hello
I heard that in ansys 13,Fluent are able to hydroacoustical analyzing,if yes ?would you please briefly explain it. |
October 20, 2011, 12:45 |
Emre G
Rep Power: 14 |
i havent heard about it. I know that there is no an actual software helping in hidroacustical areas.
Is ther anyone sure about that? |
October 20, 2011, 18:08 |
Tom M
Rep Power: 14 |
Sabra,
Please see chapter 22 in the attached link for a description of Fluent's acoustics capability. It is designed for aeroacoustics, but Fluent solves fluid dynamic equations and therefore doesn't care what the bulk fluid is so I'm sure it would work with water as well. https://www.sharcnet.ca/Software/Flu...df/ug/flug.pdf You can also see the theory the solver uses in Chapter 14 of the accompanying theory guide. https://www.sharcnet.ca/Software/Flu...df/th/flth.pdf Note that modeling acoustics in fluent is computationally intensive since the compressible model must be used along with fine meshing near the source and receiver, which makes it difficult to get far-field predictions. Hope this helps. |
Modelling the cross aisle direction of a steel selective rack for model analysis | m8rix | ANSYS | 0 | September 20, 2011 10:28 |
LES post analysis | faisal_durr | Main CFD Forum | 0 | July 13, 2011 05:52 |
3D analysis of Ahmed body | Irshad22 | FLUENT | 0 | December 17, 2009 04:33 |
What exactly is a sensitivity analysis? | Josh | CFX | 3 | August 19, 2009 09:18 |
Short Course: Computational Thermal Analysis | Dean S. Schrage | Main CFD Forum | 11 | September 27, 2000 17:46 |
