How to specify outlet pressure
Old   October 31, 2011, 04:49
Default How to specify outlet pressure
mahendra
mrdumpa is on a distinguished road
I have one doubt in FLuent. ie
I want to specify outlet pressure as 5 bar in my problem using Fluent.
If i use operating pressure as 1bar(101325 Pa). Then what value i have to specify. Whether 5 bar or I have to take relative pressure value (5-1=4bar).
Any one plz help me to sortout this problem.
Thanks in Advance
mahendra
mrdumpa is offline   Reply With Quote
Old   November 7, 2011, 03:09
delaneyluke is on a distinguished road
All calculated pressures in your domain (including outlet pressures) are gauge pressures i.e relative to your operating pressure. So your outlet pressure BC will be 4bar , if your operating pressure is 1 bar.
Alternately you could specify your operating pressure as 5 bar and outlet BC as 0 bar.
Regards
Luke
delaneyluke is offline   Reply With Quote
Problems in pressure when using mass flow rate outlet rafiktharwat CFX 11 January 2, 2014 17:21
pressure oscillation near pressure outlet boundary kino Main CFD Forum 5 April 13, 2011 11:03
Pressure Outlet setting CoG STAR-CCM+ 4 June 9, 2010 21:47
what actually is the 'zero pressure outlet b. c.' hwe001 CFX 4 June 7, 2010 15:22
Backflow occuring at a pressure outlet? Dave FLUENT 1 August 12, 2004 17:39
