Wall Problem
Old   November 7, 2011, 22:00
Question Wall Problem
Shubhankar
shubhankar.kulkarni55 is on a distinguished road
I have divided my domain into some parts for the meshing purpose. I used ANSYS Workbench for the meshing. When I import this mesh in Fluent, the boundaries of these divided parts show up as 'wall' instead of 'interior'. That is why I'm unable to integrate all the divided parts to form the whole domain.
Please help!!
Thanks!!
shubhankar.kulkarni55 is offline   Reply With Quote
Old   November 9, 2011, 07:08
Sandeep
sandeep_tu is on a distinguished road
Acutally there are many unanswered questions rising from your problem, could you explain more in detail (pictures may help) or may be try this as--
first you start the serail version of fluent and read the first mesh and then for the second mesh-->append case file (mesh->zone->append), this combines two mesh files into a sinle mesh file.
sandeep_tu is offline   Reply With Quote
Old   November 9, 2011, 12:15
Zachariah Swetky
swetkyz is on a distinguished road
shubhankar,
please see the following post: http://www.cfd-online.com/Forums/flu...tml#post331186
Hopefully that helps. The I recommend using "form new part" option in Design Modeler to make each subpart into one part since you don't need separate cell zones in your flow problem.
swetkyz is offline   Reply With Quote
Old   November 10, 2011, 01:17
Shubhankar
Originally Posted by swetkyz View Post
shubhankar,
Thanks a lot! Will give it a shot!!
Thanks a ton for your help!!
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Problem with wall function gregjunqua OpenFOAM 5 August 25, 2011 23:32
Two Sided wall Problem Mk1987 ANSYS Meshing & Geometry 0 March 26, 2010 13:37
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 13:43
