Multi-inlet problem
Old   November 13, 2011, 23:38
Default Multi-inlet problem
sachin
sachin_pathak is on a distinguished road
Hello folks, i m modelling a system which have multi inlets(3). I m trying to know how can i add respective material to respective inlet. for example inlet material are air water and sugar all entering through different inlets. how can i specify the same?
sachin_pathak is offline   Reply With Quote
Old   November 14, 2011, 03:44
Default Re:
shoeb khan
shk12345 is on a distinguished road
Do the following steps i hope that will help
1) Switch on species transport .
2) Make a new material i.e. mixture and add all the materials in it.
3) Go to boundary conditions in species tab and give the volume fraction of the species needed.
You are done.
Shoeb
shk12345 is offline   Reply With Quote
Old   November 14, 2011, 11:18
raj
raj.cfd is on a distinguished road
You need to solve this problem using Multiphase analysis with three phases...
raj.cfd is offline   Reply With Quote
Old   November 14, 2011, 11:27
Default Re
shoeb khan
Can you expmain how to solve the multiphase three phase problem and what can be the three phases.
SHK
Old   November 14, 2011, 14:40
raj
Hi Sachin,
As I understand from your post, let me explain it in detail...you have three materials Air, Water and Sugar. Air is gas phase, Water is liquid phase and Sugar is granulated phase . You would also be knowing about the volume fraction of all these three materials. As said earlier, probably you can use Eulerian dispersed multiphase model. with three phases. primary phase or continuous phase can be the material Air or water depending on higher volume fraction . The first secondary phase can be again air or water depending on lower volume fraction. The second secondary phase can be granulated sugar. Depending on your problem, you can consider all or any of the following effects viz..interfacial surface tension effects, drag co-efficients, diameter of secondary phase, coalescence and breakage and the phase inversion .....
Hope this provides some idea on the problem you are analysing, if not you can always contact Ansys Technical support, they will be very happy and willing to support you.
[swak4Foam] GroovyBC problem in the defining inlet velocity iampolaris OpenFOAM Community Contributions 7 October 18, 2014 09:25
Inlet boundary condition problem Martin_D FLUENT 1 January 10, 2013 12:58
Specifying volume/Mass fraction in Species Transport for problem without inlet tanjinjack FLUENT 1 October 9, 2011 04:42
inlet profile for 3D problem crissy FLUENT 3 August 25, 2006 07:46
Multiple frames-Coupling Pressure & Inlet problem sham Siemens 1 June 9, 2006 00:39
