natural convection in stratified zone
Old   November 12, 2011, 13:11
Default natural convection in stratified zone
cfdlame is on a distinguished road
I'm using Fluent forum, tell me if I've choosen incorrectly.
The problem is: For different solver setting I'm experiencing natural convection in zone, where initialized temperature gradient is less than the lapse rate - convection should't occure.
I'm investigating convection in closed cube 3kmx3kmx2km with adiabatic boundary condition (hex grid 150000 elements). Initialized temperature gradient is decreasing 0,5K/100m (adiabatic lapse rate is 1K/100m). I've tried: boussinesq, ideal gas, and real gas for a density model, for both solvers: density, and pressure based (presto, second order for everything). I don't even know solver type matters, probably not. UDF is written fine. In every case convection occured. Somebody have any idea?
Tomek
cfdlame is offline   Reply With Quote
Old   November 14, 2011, 04:08
any ideas? maybe I should change forum?
Old   November 14, 2011, 10:53
Sandeep
sandeep_tu is on a distinguished road
I can make some suggestions,
* May be donīt use Gravitional acceleration.
* Density is very important in FLUENT. You should choose this based up on your problem. May be this helps,
1. For compressible flows, the ideal gas law is the appropriate density relationship.
2. For incompressible flows, you may choose constant density .
all other options are used to model natural convection (for example Boussinesq model)
sandeep_tu is offline   Reply With Quote
Old   November 14, 2011, 15:00
Smile
This is not exactly answer to my question, but thanks.
Once again: In my model convection occurs, but it should't. All properieties for convection should be enabled (ideal gas, gravity, energy equation etc.) but it should not happen, because tempreture gradient is too small (below adiabatic lapse rate)
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
BC for Natural Convection in Stratified environment toyoto Main CFD Forum 0 September 2, 2009 23:10
Modelling natural convection in stratified environment toyoto FLUENT 0 September 2, 2009 23:05
