Mixture model
Old   March 24, 2010, 15:31
Default Mixture model
priyanka.asp is on a distinguished road
Hello guys,
I have a mixture of water + aluminum oxide nanoparticles. How is it ensured that the mixture has a certain value of volume concentration % of nanoparticles? (mixture model is solves the volume fraction of the secondary phase, which is the nano phase.) If I give an initial volume fraction, it solves all the conservation equations based on it. But is there any way to give input to fluent's mixture model tat has a certain volume concentration % ???
priyanka.asp is offline   Reply With Quote
Old   January 27, 2011, 10:29
atz_33 is on a distinguished road
Hi Priyanka.asp
My problem is identicle to yours, were you able to find a solution for the % of nanoparticles?
Any help wud be appreciated, thanks.
atz_33 is offline   Reply With Quote
Old   January 29, 2011, 16:29
sunny
sandisk is on a distinguished road
Hi atz_33,
I am working on a similar thing on water sand slurry multiphase flow using mixture model. I am not to get desired values for pressure drop. Can you elaborate, what simulation are you working on? and what models are you using?
sandisk is offline   Reply With Quote
Old   February 3, 2011, 16:06
daalou
alilouu is on a distinguished road
i am working on the same thing, but i used the VOF which is better than mexture model;;;;;;;;;;;;;
alilouu is offline   Reply With Quote
Old   February 3, 2011, 16:20
sunny
Can you explain me your simulation problem, I mean what are the details of the flow and the details of the problem. My mail id is naiksarvesh@gmail.com. Are you getting results according VOF model ? Thanks..
Old   April 16, 2020, 02:18
Default Did you solve the problem
Abhi
abhilasht is on a distinguished road
Originally Posted by priyanka.asp View Post
Hello guys,
I`m using mixture model for same problem. I`m having mixture velocity data. For velocity inlet boundary condition, different phase velocity is asked. Is it same as mixture velocity. How to estimate phase velocity from mixture velocity.
abhilasht is offline   Reply With Quote
Fluent's Mixture model in CFX FLuentSwitch CFX 14 December 27, 2014 09:15
Redlich Kwong real gas model for species mixture Helium and Argon anandabbai FLUENT 0 May 29, 2009 02:04
Mixture multiphase model sourplum FLUENT 1 May 19, 2009 07:27
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 11:46
about the mixture model and cavitation model lius FLUENT 2 January 11, 2006 04:55
