error reading mesh from ICEM
Old   December 18, 2011, 13:38
Default error reading mesh from ICEM
luxingzhe
luxingzhe is on a distinguished road
Dear All
I am planning to use sliding mesh model to simulate my wind tubine. i build the geometry in gambit, exported step file, and imported into ICEM for mesh. you can see from the step file that there are two parts( one is going to be stationary and the other is going to be rotating). I meshed the whole domain in ICEM, defined boundary condition, specially defined interfaces between the two domains. i ended up with 2.8 and 3.6 million elements for two different blocking strateries. however, i have problem reading the mesh in fluent, it gives me this error when building mesh in fluent :
reporting the mesh_____fine here, then
building mesh,
error: FLUENT received fatal signal (access violation).
Do anyone have any ideas about this error?
i appreciate your comments and suggestions.
Best Regards,
luxingzhe is offline   Reply With Quote
Old   December 19, 2011, 02:24
Smile
Krishna
krishnag2002 is on a distinguished road
Hi Small Suggestion...
Just check the volume mesh in Icem and conform the mesh.
if you get any errors in icem level just fix it.
krishnag2002 is offline   Reply With Quote
error, icem, mesh
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
ICEM Edit Mesh blackbody ANSYS Meshing & Geometry 3 March 8, 2010 02:49
Boddy fitted Hexcore Mesh in ICEM Cfd Mitch CFX 0 December 29, 2008 06:07
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 16:29
