December 22, 2011, 05:56 |
problme with udf
rose
Rep Power: 15 |
hi all;
Please I have a problem in the numerical simulations made by Fluent 6.3 and Ansys Fluent 12.0.16 even when I use the UDF. it is interpretable but when I put the UDF in the interaction window or in the properties of materials such as for example the viscosity between the two phase fluent displays this message: Error: FLUENT Received fatal signal (ACCESS_VIOLATION) 1. Note exact events Leading to error. 2. Save case / data Under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () knowing that I work with the VOF model. I would be very grateful if you help me solve my problem of simulation. cordially |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
