January 10, 2012, 14:31 |
Lift Coefficient Oscillates
Ming Cai
Rep Power: 15 |
Dear Friends
I'm running simulation on a NACA 64 210 airfoil with k-omega sst model with Re = 2.6 E6 . The chord length is 1m. Angle of Attack ranges from 0 to 20. everything is fine before angle of attack getting to 12, both lift coefficient and drag coefficients oscillates periodicly after 12 aoa. I don't know if this is the correct solution. However, before this angle the results are reasonable Thanks for your help. Last edited by mingersai; January 11, 2012 at 12:35. |
January 11, 2012, 12:36 |
Ming Cai
Rep Power: 15 |
Can anyone tell me how to deal with this?
January 11, 2012, 13:59 |
Ryne
Rep Power: 16 |
I would guess that the airfoil is stalling and this oscillation comes from the separation and reattachment of the airflow over the airfoil.
January 11, 2012, 14:26 |
#4 | |
Ming Cai
Rep Power: 15 |
Thanks for your reply. I'm comparing my results with experimental ones. The experimental people pick only one value for this angle of attack. I'm not sure how they did that if the airfoil is stalling. I have no experience in wind tunnel tests... |
January 12, 2012, 11:01 |
Ryne
Rep Power: 16 |
May I ask why you are running a transient case instead of just a steady case?
January 12, 2012, 11:45 |
Ming Cai
Rep Power: 15 |
January 12, 2012, 13:49 |
Tom
Rep Power: 14 |
Could it be caused by vortex shedding?
Lift coefficient in Eulerian multiphase model | hennas | FLUENT | 1 | July 4, 2011 16:50 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
Zero Coefficient of Lift Problem | MH | FLUENT | 0 | February 25, 2007 11:48 |
Lift force or coefficient of lift | Rola | FLUENT | 1 | November 12, 2006 13:29 |
Help needed - lift coefficient on front/rear axle | Jan Jagrik | FLUENT | 0 | September 21, 2000 10:21 |
