Unsteady non-uniform flow modelling
Old   January 16, 2012, 09:48
Default Unsteady non-uniform flow modelling
egge24 is on a distinguished road
I want to model an unsteady non-uniform flow in an open channel with FLUENT.
I´m assuming I have to use VOF simulation.
How can I account for the varying water level at the inlet boundary?
What types of boundary conditions I need to use?
Any help will be appreciated!
egge24 is offline   Reply With Quote
Old   January 17, 2012, 08:48
shoeb khan
shk12345 is on a distinguished road
hi
If you are using a VOF model you have to run the simulation in unsteady way first.
If you want a varying velocity you can try to run the simulation at a particular velocity for a particular time and then change the velocity at the different time .
By changing the velocity at different time you can do the simulation.
Second you can develop a time dependent equation using any software like matlab or excel and then you can built the udf for that equation and use that udf in velocity inlet for velocity profile
hope that wil help you
regars
shk
shk12345 is offline   Reply With Quote
Periodic boundary in unsteady flow ac2011 FLUENT 0 September 26, 2011 06:52
unsteady flow problems Daniel FLUENT 0 January 25, 2009 23:54
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
how to predict unsteady flow from case definition? Felix Main CFD Forum 6 August 28, 2007 16:40
About unsteady flow modelling Cagdas FLUENT 0 July 7, 2007 10:15
