January 18, 2012, 20:10 |
walls that should be interior
nazareno mancinelli
Rep Power: 17 |
hi guys. i'm working in a VAWT. i did make the mesh in gambit and imported it into fluent. the problem is that i have some interior faces and when i imported the mesh i have walls instead of interior bc.
i have two main zones: the one that its' close to the blades and the other one that's away. i set up a interface in between this two because the interior one is moving while the exterior is fixed. (first attachment) the problem is in the interior zone. i split the interior face into a lot of faces, so i can have control on the mesh close the airfoil. i liked every straight edges in around the blades so i have "interior bc" when i import the mesh into fluent. but, with the circular edges i can not link it (because they are not coincident). so as result i have a wal (like this in red thick line in the second attachment). one solution is to set it as interface without setting the periodic or coupled options. as result i have a lot of errors concerning to this interfase (third screenshot) what shoul i do? can anybody help me? thanks! |
January 20, 2012, 01:03 |
Rep Power: 17 |
One problem could be that you have 2 overlapping surfaces at that region and hence FLUENT considers both as walls, try and locate these 2 surfaces and fuse them, FLUENT will automatically create the fused surface as an interior.
Regards Luke |
January 20, 2012, 17:55 |
the solution! and extra question
nazareno mancinelli
Rep Power: 17 |
i could not do that, in the zone list to fuse, i just have the options for inlet, oulet, blades, interfase1, interfase2 and the wall (the inner edges close the blades). so, because i don't have the interior fluid zone in this list i can not fuse it with this walls.
i did do the next. i go back some steps in gambit, and split every circle of the fluid zone in such of parts as i have in the "close to the blades" zones. so i have a circle maded with some (5) arcs pieces. them, i linked every arc with the face's arc around the blade fluid zone. the result work fine when i imported it in fluent. by the way, i did run the problem in fluent and i have like a error zone close to the interface (i think). i did make a mesh refinement and the weird velocity distribution persist. what should i do? |
January 23, 2012, 02:06 |
Maxime Perelli
Rep Power: 41 |
connection problem.
To persuade you: in gambit select one small disk and move it with a translation vector. If gambit does it without error, then your 2 domains aren t connected (and then at the "interface" between both domains, you have superposed edges (circles) treated as wall in Fluent.
In memory of my friend Hervé: CFD engineer & freerider |
January 23, 2012, 13:11 |
#5 | |
Rep Power: 14 |
You have to connect the faces that are overlapping, otherwise when you export the mesh Fluent will treat the overlapping faces as wall. |
January 23, 2012, 16:33 |
nazareno mancinelli
Rep Power: 17 |
hi guys
-mAx- : that's a good way to be sure about that. i did fix the problem (last post), but i'd try your suggestion and it's totally true: you can not move it if it is connected. mali28: thanks. but i'd know which the problem was. the issue it was that i did not make any idea how to fix it. but i finally did. so, muchas gracias chi@os. suerte con sus simulaciones! |
boundary conditions, interface, interior, vawt, wall |
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench | aarvay | ANSYS Meshing & Geometry | 11 | January 12, 2017 12:51 |
[Commercial meshers] Importing a mesh from Gambit Interior faces that are walls | gschaider | OpenFOAM Meshing & Mesh Conversion | 84 | September 11, 2011 03:27 |
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls | david39 | OpenFOAM Running, Solving & CFD | 6 | January 18, 2011 11:49 |
Boundary conditon about interior | zhou | FLUENT | 0 | September 19, 2003 18:00 |
thermal conditions of walls | Stefan | FLUENT | 2 | March 23, 2003 06:17 |
