January 25, 2012, 00:02 |
Fluent Parallel Processing Issue
Vijay
I used to run fluent on parallel mode. Recently, they have re-booted the cluster and I am getting this error below. Previously it was fine. I appreciate if some one can help me. It is urgent. Thank you
/usr/ansys_inc/v130/fluent/fluent13.0.0/multiport/mpi_wrapper/bin/mpirun.fl: line 2074: default_run: command not found |
January 25, 2012, 09:55 |
shoeb khan
which college are you from
this happens after the boot of server this can help you try to browse it by using the linux commands in the console you will find it try to go to licence manager and set the licence preference for the user your name there click on fluent 13.0 and its done hope that will help you |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
Fluent Parallel SUPPORT | MOHAMMED TOLBA | FLUENT | 1 | February 20, 2006 01:27 |
error parallel fluent session | Diet | FLUENT | 2 | January 27, 2005 12:31 |
Help: Batch file for Parallel Processing ( 2CPU ) | SC | FLUENT | 1 | July 15, 2003 21:34 |
