Minimum Volume Fraction
Old   January 27, 2012, 08:25
Default Minimum Volume Fraction
rkd2012 is on a distinguished road
I am having some problems with the simulation of multiphase flow using the eulerian-eulerian approach with Fluent 13. The results of the particle velocity presented velocities near zero (not expected) in locations where the volume fraction was smaller than aproximattly 5E-7. I tested in other positions and this value of volume fraction showed to be the limit between a reasonable and an extrange result. Is there any way to set up the minimum value for the volume fraction in order to avoid such problem, or any other idea? This problem appeared for the RSM and k-epsilon turbulence model.
rkd2012 is offline   Reply With Quote
Old   January 29, 2012, 12:08
a
a_kaffash is on a distinguished road
can you explain more about you case? I mean geometry and boundary conditions
a_kaffash is offline   Reply With Quote
minimum volume fraction
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
