Fluent to Tecplot - 3D slice Velocity Magnitude
Old   January 30, 2012, 11:51
Default Fluent to Tecplot - 3D slice Velocity Magnitude
Emma
emmkell is on a distinguished road
Hi
I'm currently post processing 3D case and data files in Tecplot. I am trying to get a vector plot of the Velocity magnitude on the cross section plane of the mesh. I have created a slice where I want the vector plot.
When I go to select the variable to plot, it doesnt give me the option to plot Velocity Magnitude, only X Vel, Y Vel or Z Vel.
Does anyone know if there is a way of fixing this?
emmkell is offline   Reply With Quote
Old   January 30, 2012, 12:12
Emma
Just found the answer to this on a different thread on the forum (thanks fremdar!!)
I thoguht i'd post it here anyway in case anyone is having a similar problem:
Export a CGNS file from Fluent (selecting velocity magnitude for me)
Open the CGNS file in Tecplot using the CGNS Loader in the Tecplot 'Import' menu
Old   January 30, 2012, 14:16
Amir's Avatar
Amir
Amir is on a distinguished road
It has simpler way! you can define new variables in Tecplot:
Data->alter->specify equation ....
Bests,
Amir
Amir is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Output velocity magnitude satellite_control FLOW-3D 1 November 30, 2011 19:07
How to indicate velocity magnitude in tecplot with Flow-3d file? his124 FLOW-3D 1 June 27, 2011 10:54
tecplot 3D velocity contours inside a channel vetnav Tecplot 4 July 14, 2010 20:03
postprocessing Fluent Tecplot unknown FLUENT 0 October 11, 2009 06:34
