dynamic mesh
Like Tree1Likes
  • 1 Post By Amir
Old   February 2, 2012, 01:28
Default dynamic mesh
Kim Donghee
ssamton is on a distinguished road
Hi there
i want to simulate like piston movement!
as shown in attached file, center line moves upward as time goes.
i used dynamic mesh(smoothing&remeshing).
so, center line moves well, but, does not working remesh function.
just move center line upward.
therefore, when center line arrive adjacent cell(i.e, adjacent upper cell), show error message: Negative cell volume.
please help me.
I'm just trying to studying dynamic mesh.
it's very simple problem, i think.
Ah, I also use UDF(CG_MOTION)
Thank you all.
Have nice day
ssamton is offline   Reply With Quote
Old   February 2, 2012, 03:36
Amir's Avatar
Amir
Amir is on a distinguished road
The best dynamic mesh technique for this purpose is "layaring". but if you insist on using smoothing, you have to enable it from TUI for all the cell types; additionally, I don't think that the quad elements can be remeshed.
Bests,
Amir
Amir is offline   Reply With Quote
Old   February 2, 2012, 04:17
Kim Donghee
Thanks Amir
i just want to simulate through any method.
first of all, i try to layering method
however, could you tell me more way to set up?
i read manual, but it's really hard to understand.
Thank you again.
below coding is mine and i hooked up only center line.
#include "udf.h"
DEFINE_CG_MOTION(butterfly_flex_UDF, dt, cg_vel, cg_omega, time, dtime)
cg_vel[0] = 0.0;
cg_vel[1] = 0.1;
cg_vel[2] = 0.0;
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
cg_omega[2] = 0.0;
Old   February 2, 2012, 04:25
Amir's Avatar
Amir
Ok, your UDF looks fine. As I said the other methods aren't recommended in such movement. The onlt tip that you have to consider in layering method is just setting the cell height of each dynamic zones from mesh options tab.
Bests,
ssamton likes this.
Amir
Old   February 2, 2012, 05:53
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
same topic here >> http://www.cfd-online.com/Forums/ans...ic-engine.html
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 4, 2012, 01:40
Kim Donghee
Thank you all^^
i solved this problem!!
thank you again!!
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 10:42
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
