July 19, 2011, 12:19 |
Evaporation with population balance model
Li Huang
Rep Power: 15 |
Dear friends,
I have been modeling water droplets evaporation with Population Balance Model. My problem is that particle volume fraction does not converge very nicely, although overall mass is well balanced. In my case, I use mixture model. Mass transfer from liquid drops to vapor phase (air+water vapor) is defined through DEFINE_MASS_TRANSFER. At the same time, changes in liquid drop's diameters is defined through DEFINE_PB_GROWTH_RATE. Residual plots are generally good for all other parameters than volume fraction of liquid particles (to only about 0.1 level). Shall I also introduce source of energy and/or momentum to the mixture phase and source of particle volume fraction to particle phase to get nicely converged results? Thanks for your suggestions. |
January 28, 2012, 11:27 |
Vaibhav Rai Khare
Rep Power: 14 |
Sir,
i am working on same problem of yours. i also used mixture model and discrete model for population balance model.how can i give the nucleation rate and growth rate in this model for water vapor. and if you can tell what is the concept of Min and Max Bin size. How it can be defined.? help if you plzz... |
January 28, 2012, 22:50 |
Li Huang
Rep Power: 15 |
Both rates were defined in Udfs. Or you can set constant rate. If you are using fluent 13.0, you need to click the phenomena option under PBM settings window to make changes on nuclear ion rate.
January 28, 2012, 22:56 |
Li Huang
Rep Power: 15 |
The min and max bin size are defined in the PBM settings window. You can check out the theory's guide for the calculation of each bin between min and max bins. You can also print out all bin size by one click there. Good luck
February 5, 2012, 01:19 |
Vaibhav Rai Khare
Rep Power: 14 |
Dear Lihuang,
i am still not getting my results, volume fraction does not converge..as there might be some problem in PBM or UDF. Can you tell me if i want to give the constant mass transfer value for it what it will be??? and i haven't found any UDF for PBM to specify the growth rate and nucleation rate. |
Display Modes | |
coupling population balance with reaction | mehdi kamyabi | FLUENT | 7 | December 5, 2015 02:14 |
Using population balance model | payam_IUST | FLUENT | 0 | December 6, 2010 02:12 |
Population Balance Model in FLUENT | sunny2009 | FLUENT | 0 | August 13, 2009 12:35 |
population balance model | mustafa | FLUENT | 1 | February 28, 2008 15:21 |
population balance with and Euler Euler method. | thomas | Main CFD Forum | 0 | May 7, 2004 08:58 |
