reversed flow in 1270 faces on pressure outlet |
February 8, 2012, 07:15 |
tichaona
Rep Power: 14 |
Dear collegues
I am getting the message reversed flow in 1270 faces on pressure outlet 23 during calculating solution with Fluent. The same message is coming after every single iteration. Is this an error? Thank you in advance for any reply. |
February 8, 2012, 07:27 |
Rep Power: 17 |
This belongs in the Fluent section.
No this is not an error, it just tells you that your outlet somewhat acts as an inlet, most likely because of its position relative to the real inlet. You can also get the message early on in the iterative process before the flow field has stabilized. So I suggest waiting a bit and/or move the outlet if possible (outlets should be far from the inlet and the flow should also be in the outlet normal direction if possible). gl hf
"Trying is the first step to failure." - Homer Simpson |
Outlet pressure for compressible flow | Michelle | CFX | 12 | September 1, 2015 18:38 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
pressure outlet BC for incompressible flow | khaiching | Main CFD Forum | 6 | October 15, 2005 02:58 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
