February 9, 2012, 07:21 |
How can I compare two cases side-by-side?
The FLUENT documentation says it's possible to compare two or more case files side by side. Do you know how to do it?
Regards |
February 9, 2012, 08:59 |
litter
what's that
never ever give up |
March 29, 2012, 09:44 |
I am interested in this as well
March 29, 2012, 18:48 |
Hello Zigainer.
If you're using Workbench, then you can simply link 2 fluent cases to CFD post in the work table layout. If you're firing up CFD post as a stand-alone you need to click on 2 or more views. Then, open your first results file. Click on the second view pane and then open your second results file. Just like that. Give me a shout if this works. |
March 30, 2012, 02:34 |
it work fine for two windows! Thanks. But one more question, is it possible, that the view(direction) in both views are the same? So that I simply can change the view in one window and the second window is changing automatically. |
March 30, 2012, 04:40 |
synchronize view on cfd post
Yes it's possible! You just have to click on the button where there is a padlock ! Just at the top of the view.
You can also compare cases with a simple operation (+ or - ...). See at the "Tools" menu . It's very useful. |
March 30, 2012, 06:05 |
..... I can't see a padlock ... and neither do I have a "tools" menu ....
Or I maybe just don't see it .... |
March 30, 2012, 06:36 |
I have the versions 13.0
I have the 13.0 version. Maybe that is the reason.
I join with this post a view of CFD post that I have ! |
April 16, 2012, 14:54 |
Your picture looks like CFX 13.0 not Fluent 13.0
April 21, 2012, 12:40 |
I want to know if the visualization and comparison of two case files is possible on fluent 6.3
and if I can visualize the variation of a parameter in a given piont with time (unsteady) |
April 22, 2012, 16:05 |
#12 |
thank you for your reply, but what are the steps to follow to save a picture and read the second file case .
April 23, 2012, 04:32 |
#13 |
April 23, 2012, 07:44 |
#14 |
April 23, 2012, 15:21 |
#15 |
April 25, 2012, 05:06 |
#16 |
Axysimmetric cases compare to planar case with symmetry boundary condition | hafiidz | FLUENT | 5 | June 14, 2011 06:29 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 08:58 |
