February 20, 2012, 02:53 |
Time-averaged result in transient FLUENT simulation
linlong
Rep Power: 14 |
I'm working on FLUENT with transient mode. And I hope to get the time-averaged contours of the results. I have tried with paraview. It seems like paraview can only read data with a time step; however, a set of time series transient data can not be imported to the paraview. Does anyone know how to post process it? Thanks a lot. Last edited by lgas222; February 20, 2012 at 03:13. Reason: explain more |
February 20, 2012, 08:20 |
Re
Domenico
Rep Power: 14 |
hi
not totally sure, but if you are using for example RANS, then the results are already time-averaged, i.e. they are averaged on your time step, whatever time level you are looking at. regards |
February 20, 2012, 08:38 |
#3 | |
linlong
Rep Power: 14 |
Thanks. I use k-epsilon viscous model. Do you know how can I get the time-averaged contour between, eg. 1-100s, with paraview or tecplot? As I knew from my colleague, we can use matlab to deal with it. But I haven't tried that. |
February 20, 2012, 11:39 |
Re
Domenico
Rep Power: 14 |
hi
what i know is that if you are simulating the RANS, so not LES/DNS, then your solution is already integrated over the time step you are using. aside from the numerical aspects your time step can lead, it should be longer than the typical duration of fluctuating components, but it should also allow for the possibility of variations in mean quantities to describe unsteady conditions in the mean fluid motion, thus the time step cannot be too long. this means it depends on the problem you are solving, but however i don't know how to average in ''other'' times outside Fluent; i know it is possible with Tecplot in a relatively easy way, but honestly i don't know how regards |
fluent, post process, time averaged, transient |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Reg - Log result | hariya03 | OpenFOAM | 2 | February 15, 2011 05:32 |
Transient post-processing, Time averaged pressure work | Turbomachine | CFX | 1 | January 3, 2011 17:01 |
how do I export the time series of the result? | empirer2002 | CFX | 3 | April 16, 2008 07:33 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
