Wall Roughness
Like Tree9Likes
  • 3 Post By pmbov
  • 6 Post By ghost82
Old   February 24, 2012, 14:45
Default Wall Roughness
Paul
pmbov is on a distinguished road
I am trying to get a better understanding of what the "Wall Roughness" box is (in the wall boundary layer box) referring to.
Roughness Height:
Is this the height found on standard charts? (see http://www.engineeringtoolbox.com/su...cts-d_209.html).
i.e. If I was to use Stainless Steel than the Roughness Height would be k=5E-5ft.
Roughness Constant:
Is the roughness constant the number calculated (relative roughness).
i.e. Using the hydraulic diameter (d=23.5in), and k. Equation is r=k/d == having a value of 26E-6.
Can someone please help?
Thank you!
Paul
etinavid, prasa and bolbol like this.
pmbov is offline   Reply With Quote
Old   February 24, 2012, 14:57
ghost82's Avatar
Rick
ghost82 will become famous soon enough
You are right for the roughness height, but roughness constant isn't relative roughness: fluent uses this parameter to specify uniformity of roughness: since there is no indication on how to calculate it, you have to try and see if your simulation results approximate your experimental results; roughness constant=0,5 indicates a uniformal roughness; use values between 0,5 and 1 to specify non uniformal roughness.
Daniele
TallesC, dynamic, etinavid and 3 others like this.
ghost82 is offline   Reply With Quote
Old   February 24, 2012, 15:54
Paul
Thank you Daniele, I appreciate your very quick responds.
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 21:22
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Roughness Height of a wall Vijay FLUENT 0 December 17, 2009 15:13
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Wall Roughness Error Ken FLUENT 1 April 23, 2007 12:59
