how to set BC of cyclone separator outlet
Old   September 6, 2004, 03:39
Default how to set BC of cyclone separator outlet
Lcw
In simulation of cyclone separator, the BC of outlet is often defined as "pressure-outlet" or "outflow", which one is best for the case of closed operation? that is, the outlet of cyclone is linked with a centrifugal fan.
thanks
Lcw
Old   September 9, 2004, 10:36
Default Re: how to set BC of cyclone separator outlet
fpingqian
When we don't know the outlet pressure, we can difine it as outflow.
Old   September 10, 2004, 09:25
Lcw
If we define outlet as "outflow", the exit pipe of the cyclone model need to be prolonged, in general, how long does we choose the length of exit pipe? supposing cyclone cylinder diameter is 170mm, exit diameter is 85mm.
In fact, swirl flow must be 3-dimension, how much error beteen the 3-dimension swirl flow and the developed outflow?
thank you!
Old   October 3, 2004, 08:51
ap
In my opinion you can get better results and a better convergence behaviour using the pressure outlet boundary condition.
Hi
ap
Old   October 5, 2004, 09:41
Lcw
Thank you for response to my question, Downstream of my model is connected to a centrifugal wind machine, and can not use pressure outlet boundary condition.
Old   February 22, 2012, 01:40
arjun
arjun3020 is on a distinguished road
Hi all,
how to define wall boundary conditions.
i think it is reflect.
and at inlet- velocity inlet
at outlet- pressure outlet.
but what about DPM tab in Boundary conditions. Trap, escape and reflect.
which conditions should i use at inlet and outlet?
arjun3020 is offline   Reply With Quote
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 04:31
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 12:44
$FOAM_USER_APPBIN & LIBBIN variables not set rassilon OpenFOAM Installation 2 February 16, 2010 20:54
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 01:40
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
