compressible flow through porous media
Old   March 3, 2012, 00:13
Question compressible flow through porous media
Chirag
Chirag2302 is on a distinguished road
I am trying to model a oscillatory flow(fluid will move back and forth from heat exchanger at the rate of oscillation 300Hz) through the heat exchanger of very small size. For that I am considering or modeled heat exchanger as a porous media and I want to maintain the temperature of heat exchanger at 600 K and gas temperature is less than the heat exchanger temperature. So, heat will flow from heat exchanger porous material to the gas.
For this situation, I am modelling compressible flow (I think, I should use Density based solver...?) through porous media. But during the input of porous media in fluent "Fixed Value" option is not working when density based solver is activated. It is only working with Pressure based solver.
Any one can guide me on this.........? How can I set the constant temperature of porous media while using density based solver?
Chirag2302 is offline   Reply With Quote
porous media input
Compressible flow through porous media? JoFFe CFX 2 November 1, 2010 05:50
Question for modelling flow in porous media legendyxg FLUENT 9 April 21, 2009 23:24
no converge - for Low Re Porous media seepage flow lee CFX 3 August 31, 2007 02:12
unidirectional flow in porous media Brian FLUENT 6 September 2, 2004 11:53
Simulation of Porous Media Flow Sharad Dugad FLUENT 0 December 24, 2001 02:57
