February 27, 2012, 02:25 |
Help: Turbulent viscosity
Musango Lungu
Rep Power: 14 |
I am receiving the message turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1430 cells in my simulation. I am modeling a gas-solid fluidized bed reactor. How do I solve this problem? Anyone?
February 27, 2012, 03:21 |
Rep Power: 17 |
Reduce your relaxation factors
Regards Luke |
February 27, 2012, 06:14 |
Musango Lungu
Rep Power: 14 |
Thanx alot friend. I reduced the under relaxation factors but still the problem persisted for a while and then disappeared!
February 29, 2012, 02:06 |
APPLE
Rep Power: 14 |
First,check your mesh quality,refine it.then check your boundary definition
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
Too low temperature at combustor outlet | romekr | FLUENT | 2 | February 6, 2012 10:02 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 12:44 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
