How to define hydraulic or total efficiency in a centrifugal pump?
Old   February 28, 2012, 14:53
Default How to define hydraulic or total efficiency in a centrifugal pump?
spk
spk is on a distinguished road
Hi guys,
I simulate a 3d centrifugal pump using Fluent.
How can i define the hydraulic efficiency?
Or the total efficiency? The moment of the pump can be calculated?
Thanks
spk is offline   Reply With Quote
Old   February 28, 2012, 16:24
spk
Total pump efficiency = ρgQH/M2πn
ρ=water density
g=gravitational accelaration
Q=flow rate
H=total head
M=moment
π=3.14
n=rotational speed
The moment can be calculated Report-> Forces-> Moments?
I chose moment center and the zone of the rotating impeller. Moment center is the center of the impeller?
The result is the total net moment? Fluent prints 3 values of the moment x, y, z. What can i do to obtain the final value of the moment in order to calculate pump efficiency? I just sum the three moments taking into consideration the positive and negatie signs?
Lastly, i use the MRF model.
Old   March 4, 2012, 04:14
Post
a.farid
A.farid is on a distinguished road
hi can yo tell me about the meshing tool
A.farid is offline   Reply With Quote
Old   March 4, 2012, 04:18
a.farid
hi farid what is your meshing program
Old   March 5, 2012, 08:40
spk
I use Gambit.
Old   March 6, 2012, 01:54
Post
a.farid
may i have a tutorial how to model a centrifugal pump with three zones inlet, outlet and impeller
Old   March 16, 2012, 06:32
spk
Any ideas?
Old   March 17, 2012, 03:53
Post
a.farid
I need any tutorial to start meshing a centrifugal pump by gambit
Old   March 17, 2012, 08:27
spk
I don't have any tutorial in order to mesh a centrifugal pump! You can read the fluent tutorials about meshing in general!
Old   March 18, 2012, 00:57
Post
a.farid
thank you for help
Old   March 28, 2012, 19:03
spk
Any ideas please!!!
Old   March 29, 2012, 05:36
Post
  #12
a.farid
send your e mail to me and i will send you a paper apout how to define efficiency
Autoblade centrifugal pump template mahdi balali Fidelity CFD 3 February 18, 2014 08:56
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
cavitation impeller centrifugal pump mino2006 CFX 2 September 19, 2007 12:16
boundary condition impeller centrifugal pump mino2006 FLUENT 2 December 28, 2006 18:07
Torque calculation in centrifugal pump novice Siemens 0 August 11, 2004 05:47
