Validating a paper on wing tip vortices
Like Tree1Likes
  • 1 Post By fayaazhussain
Old   March 21, 2012, 03:43
Question Validating a paper on wing tip vortices
pravin kumar
holy is on a distinguished road
Hi ppl,
I'm trying to validate "Numerical study of a wingtip vortex in the near field" by Dacles-mariani et al. In this paper they have validated using a code written by them which is "fifth order accurate" and they used a modified Baldwin-Barth as the turbulence model. They have also added that third order accurate scheme was too dissipative. I'm trying to validate this paper in fluent which is limited to third order accurate scheme and no turbulence model such as Baldwin-Barth is available in fluent.
The link below is a paper which tried to validated that same Dacles-Mariani paper.
http://wvuscholar.wvu.edu:8881//exli...8xMzYxNQ==.pdf
I ran iterations in fluent giving the following parameters as given in the above link.
Boundary conditions:
Working condition: 101325 pa
Velocity inlet : 170ft/s
pressure outlet: 0 pa (reference pressure)
All others are kept as stationary wall except the wall of symmetry.
Turbulence model : SPALART ALLMARAS.(S-A)
Scheme: SIMPLE
Gradient: LSQ CELL BASED (Least square cell based)
Pressure: second order
Continuity:QUICK
Momentum:QUICK
But i can't get good results. The results i'm getting are far more deviated from the actual results.
Can anyone help me to get better results?
Thanks in advance.
holy is offline   Reply With Quote
Old   March 21, 2012, 09:46
Default Dear Mr. Drogi
Fayaaz Hussain
fayaazhussain is on a distinguished road
indha forum la un doubt ketta solluvaangala? poda dai pacha drogi!
holy likes this.
fayaazhussain is offline   Reply With Quote
Old   March 22, 2012, 02:28
Default Dear Guru
pravin kumar
SUMO.
Public Public.
Old   May 2, 2012, 23:26
Kalyan
kalyangoparaju is on a distinguished road
Holy,
I am doing the same thing as a part of the research for my Ph.D. There is no way you can get good results from a standard turbulence model. It is too dissipative and the results will be off by a lot.
Kalyan
kalyangoparaju is offline   Reply With Quote
Old   May 3, 2012, 06:20
pravin kumar
Hi kalyan,
In your geometry did you use trips near the leading edge of your wings?
boundary conditions, daclec-mariani et al, fluent, wing tip vortices
[ICEM] 3D wing tip realanony87 ANSYS Meshing & Geometry 3 November 6, 2019 13:34
Wing Tip Vortices dfitz1000 FLUENT 9 May 16, 2016 11:19
CFD of 3D Wing Tip Blowing NLao Main CFD Forum 1 March 1, 2012 01:44
[ICEM] Structured Mesh 3D Wing Tip Michiel ANSYS Meshing & Geometry 5 October 21, 2010 08:39
Wing tip vortices using Fluent Jainy FLUENT 3 August 22, 2005 19:13
