Solid Properties Setup In Simulation of Porous Media |
March 21, 2012, 20:54 |
Samuel
Hi guys~
In order to simulate heat transfer between gas and solid in porous media, I add an additional UDS which represents the solid energy equation. Meanwhile, I still want to use the porous media(PM) energy equation given by FLUENT to calculate the heat transport in gas. So I have to remove all solid items in PM equation by setting all solid properties (Cp\density\conductivity) ZERO!!! Is this the right way to build the double energy equation model? Regards |
March 24, 2012, 00:22 |
#2 | |
Lucky
Rep Power: 65 |
Don't forget that in addition to the material properties, you also need to specify the porosity! If you want to calculate heat transport only due to gas, an even easier method is to set the porosity to 0. porosity = 1 will give you the opposite extreme. But changing the porosity will also change the way the momentum is dealt with, so this is probably not what you want to do in this case. |
March 26, 2012, 03:20 |
#3 | |
Samuel
Thanks for your reply. I think I completely understand your words. But one assumption that FLUENT make is thermal equilibrium between gas and solid, and this is not the situation of mine, which contains combustion and sufficient convection heat transfer in the model. So, when I use the equation which FLUENT has to solve the gas energy equation (only), I can set the porosity 0. However, with this, I cannot using the physical velocity, as you said. What I want to do is keep the porosity (like 0.39), and at the same time, remove the influence of solid, just like setting porosity 0. I just don't know what I've done is reasonable or not (-by setting all solid properties 0). I hope I've express my thought clearly. Kind regards, Samuel |
March 26, 2012, 03:37 |
#4 | |
Lucky
Rep Power: 65 |
March 26, 2012, 05:00 |
#5 | |
Samuel
transient Simulation with porous media | Chrisi1984 | OpenFOAM Running, Solving & CFD | 6 | August 26, 2015 16:13 |
Porous Media coupled with internal flow | Samuel Andrade | FLUENT | 2 | August 26, 2012 09:43 |
porous media in CFX | X. Shen | CFX | 2 | September 4, 2010 06:46 |
Porous media : simulation of an heat exchanger | Arnaud | FLUENT | 6 | October 19, 2009 04:45 |
Tube bundle simulation using porous media | Jitendra | Main CFD Forum | 2 | April 13, 2004 07:57 |
