August 21, 2013, 07:06 |
Supercritical Fluids
kaveh
Hi everybody,
i'm solving a problem with fluent but i cant solve problem with two material (phase) in fluent. my problem is 3D. We are dealing with some of solid particles in sylinder Fluid phase come from bottom and solve part of the solid particles by itself and carry out it from sylinder We want to determine the extraction rate as a function of time. My fluid is co2. The following major assumptions must be made 1.Solid particles are spherical, mono-sized and lumped with respect to concentration. 2.Temperature and pressure are uniform across the extractor. 3.The radial concentration gradients in the extractor are neglected. 4.Although several components are present in the extract, their mass-transfer behaviour is assumed to be similar and is described as a single pseudo-component. 5.Local equilibrium exists at the interface of the fluid and solid phases, and the equilibrium relationship is linear. 6.The volume fraction of the extractor is not affected by the reduc-tion of the solid mass during extraction. In other words, the solids do not change their volume during the extraction process. 7.The physical properties of the solvent do not change during extraction. 8.The solvent velocity pattern is that of plug flow and assumed to be constant across the extractor. Last edited by kavehmch; August 22, 2013 at 14:56. Reason: Supercritical Fluids |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 16:35 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid hot volume in fluid cold volume | zahid | FLUENT | 4 | June 1, 2002 09:11 |
