File import problem
Old   June 28, 2006, 20:06
Default File import problem
kiran
When I try to import some *.stp (STEP) files into Gambit, I have an error "Translation requires license feature Geom-Trans...Translation failed". Any help regarding this would be appreciated. Thanks all, Regards.
Old   June 28, 2006, 23:13
Default Re: File import problem
mAx
you need this Feature in your lincense. it seems you don't have it, which sounds weird, because it supposed to be include in "normal" license (I assume)
Old   July 9, 2006, 19:30
Burny..
This is due to your license. Your license does not have a permit to use 'Geom-trnas' or you didn't install 'Geom-trans'.
Please check your lincese file or reinstall the Gambit..
Old   July 13, 2011, 06:51
Centurion2011's Avatar
Centurion2011 will become famous soon enough
I reinstalled Gambit and then it worked for me...
Centurion2011 is offline   Reply With Quote
Old   March 29, 2012, 07:15
Aydın Dönmez
donmezayd is on a distinguished road
i did the same but it didn't worked. what can i do?
donmezayd is offline   Reply With Quote
Old   March 29, 2012, 08:14
reinstall it again
Old   March 29, 2012, 13:53
Aydın Dönmez
i did it 3 times. its still the same
Old   March 30, 2012, 02:33
try ansys geometry and mesh modeller instead of gambit
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
