October 27, 2011, 16:10 |
Negative cell volume problem
dandan xiao
Rep Power: 14 |
I'm doing a dynamic mesh simulation with in-cylinder combustion. My mesh is OK when imported into fluent. However, I got this error after several itterations:
Updating mesh to time 4.00000e-04 (step = 00045) (crank-angle = 184.80)... Warning: non-positive volumes exist. Error: Update-Dynamic-Mesh failed. Negative cell volume detected. Error Object: #f How can I fix this? |
November 1, 2011, 14:15 |
Boudour
Rep Power: 14 |
i have the same problem
the negative cell volume exists when i preview the apdating the mesh have you found the problem |
November 2, 2011, 03:01 |
negative volume
Vaze
Rep Power: 16 |
Hi schuny and roukaia
Please follow the strategy given in the tutorial on piston displacement because for such problem there should not be any problem. Regards mvee |
November 3, 2011, 13:58 |
Boudour
Rep Power: 14 |
thank you for replying
do you mean the tutoriel of dynamic mesh (smoothing layering ) regards |
November 5, 2011, 03:09 |
-ve volume
Vaze
Rep Power: 16 |
You can solve any problem based on smoothing and remeshing.
November 5, 2011, 10:52 |
GAMBIT :structured & unstructured mesh in one face
Boudour
Rep Power: 14 |
dear mvee
yes i agree with you but i have also the layering method wich need a structured mesh (the layering zones valves must be in quadr) there is a joint piece for more details Attachment 9871 please have you got any idea about how to construct (a structured & unstructured mesh in one face in gambit because i think that 's the main problem of negative volume any will be appreciated Last edited by roukaia; January 9, 2012 at 12:52. |
November 5, 2011, 10:59 |
Boudour
Rep Power: 14 |
more details about my mesh and even the error in the joint piece
Updating mesh to time 3.88889e-04 (step = 00007) (crank-angle = 363.50)... Warning: negative volume detected --> repeat smoothing! Warning: negative volume detected --> repeat smoothing! Warning: negative volume detected --> repeat smoothing! Warning: non-positive volumes exist. Error: Update-Dynamic-Mesh failed. Negative cell volume detected. Error Object: #f Last edited by roukaia; January 9, 2012 at 12:52. |
November 5, 2011, 11:02 |
need help for meshing in gambit
Boudour
Rep Power: 14 |
more details about my mesh in the joint piece
April 10, 2012, 05:16 |
solution
#9 |
Vaze
Rep Power: 16 |
Hi
Did you solve the issue? Pl update me. Regards mvee |
Cell has a zero or negative volume | Nick | Siemens | 10 | February 12, 2020 20:06 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Negative volume in mesh motion | skarp | CFX | 5 | July 11, 2007 23:51 |
