May 15, 2018, 11:34 |
Quadrupole magnet coil heat transfer
Jakub
Rep Power: 7 |
I received a task to do a heat transfer analysis of a quadrupole magnet. It consists a magnet coil with a water flowing inside a circular hollow cooling the magnet. Please find here: https://www26.zippyshare.com/v/hPiLv4q3/file.html https://www26.zippyshare.com/v/ve3FXThn/file.html the catia and .stp file showing the construction. Could you do it or show something similar? I have been watching many videos covering similar topics, but I found it very hard to implement in my case from my perspective. The biggest problem I have is with setting the boundaries, The magnet generates 0,95kW and the water inlet temperature is 298K and the ambient temperature is 293K. The problem is that I get all the errors regarding the solver and the divergence, actually I tried to do it in several different ways, but always no success. I have also been wondering if this could be done with the steady-state thermal workbench module. I would really appreciate any help. Thank you. Best regards, Kuba |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
UDF for mass and heat source with heat transfer | rajendra1 | Fluent UDF and Scheme Programming | 35 | October 13, 2017 04:04 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
