Mass imbalance causing no convergenc: domain IS supposed to be positively pressurised |
April 10, 2012, 06:24 |
Rep Power: 17 |
I'm having trouble converging a case of a building ventilation system which is positively pressured hence the mass imbalance. More air goes in than comes out the vents. In reality building leakage takes care of the rest.
But what can I do in Fluent to sort this out and allow the case to converge? |
April 10, 2012, 22:57 |
#2 | |
Lucky
Rep Power: 65 |
You need to account for the mass leakage. Or reduce your mass coming in, either way you'll never get them to balance exactly. You need to relax your boundary conditions a bit. CFD is only a tool to help you understand the problem, don't become a slave to it. Make engineering approximations! Use a pressure outlet or something that makes sense (more sense than having more mass coming in than leaving). You already knew that in real life flow leakage takes care of the mass imbalance, now what can you do in the CFD to take care of it? |
April 11, 2012, 04:38 |
#3 | |
Rep Power: 17 |
April 11, 2012, 08:03 |
#4 | |
Lucky
Rep Power: 65 |
Don't overcomplicate things. Give the CFD what it needs and get on with your work/life. Unless you really want to know what flow through cracks looks like. How much do you care and how much are you willing to do? |
April 11, 2012, 18:04 |
#5 | |
Rep Power: 17 |
Then why do I do grid independence studies if I'm going to end up converging to a solution that's probably BS to start with? And hence it's extremely difficult to draw any legitimate conclusions from this type of CFD? |
April 11, 2012, 22:13 |
#6 | |
Lucky
Rep Power: 65 |
We make these assumptions and simplifications in order to get rid of the unnecessary details so that we can perform analysis and get meaningful results. Now, if you can keep all the details and still get the analysis done, then more power to you. I am not saying that it is difficult to make legitimate assumptions. I am saying the opposite; it is much simpler to make legitimate conclusions by making assumptions! So why make your life more difficult? |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 32 | February 3, 2021 03:37 |
Species Mass Imbalance | natantyt | Main CFD Forum | 0 | June 30, 2011 13:56 |
Mass imbalance definition | Asghari | Main CFD Forum | 0 | January 7, 2007 12:59 |
Why always imbalance over 134% for P & Solid Mass? | Liwau | CFX | 0 | March 11, 2004 22:52 |
OutletBoundary Condition Causes Mass Imbalance | Andy | Main CFD Forum | 0 | March 11, 2004 14:05 |
