Conjugate heat transfer.
Old   April 12, 2012, 14:47
Default heat transfer problem.
A7A
AHMAD
A7A is on a distinguished road
Hi.
I am modeling a 2d ribbed channel conjugate heat transfer problem, and i dont know why Nusselt number isnt converging, it continuously decreasing and i dont get the right answer, is it because of the mesh quality or what?
The mesh quality:
Maximum cell squish = 5.56618e-01
Maximum cell skewness = 7.85956e-01
Maximum aspect ratio = 8.35512e+00
Thank you.
A7A is offline   Reply With Quote
Old   April 12, 2012, 15:56
Zigainer is on a distinguished road
Can you add a picture of your mesh.
What are your boundary conditions? Which turbulence model?
Zigainer is offline   Reply With Quote
Old   April 12, 2012, 16:06
A7A
AHMAD
Hi Zigainer.
I am using SKW turbulence model, and periodic boundary condition at a flow rate 0.0963 kg/s, and heat flux 2500 W/m2.
Old   April 12, 2012, 16:25
Have you checked your y+? I guess you want to resolve the boundary layer and not using wall function.
Have you thought about using a "prims" layer for the boundary ....
Could you post a picture of your near wall mesh? Maybe you have to less cells within the boundary layer.
edit: and btw can you change your title, because this is not a conjugate heat transfer problem ;-) (you only simulate the fluid and not fluid&solid)
Old   April 12, 2012, 16:44
A7A
AHMAD
Thank you for the correction, and about checking y+ I've tried to make y+ adaption in fluent and it told me that there is 0 cells that have y+ bigger than 1, Finally could you tell me more about using a "prims" layer for the boundary.
Old   April 12, 2012, 16:50
When you do not want to use wall function it is not only important that y+ is less than 1, fluent also requires about 10 cells within the boundary layer. the y+ you get is only of the first cell.
For prism layer: http://www.isrn.com/journals/re/2012/528418.fig.005.jpg
If you make a grid like this, you do not ne adaption and you have good control of the boundary layer (y+ and numbers of cells).
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 06:33
Conjugate heat transfer kiteguru CFX 2 January 9, 2012 15:57
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
