Home > Forums > Mesh Generation & Pre-Processing Software > GridPro
Mesh generation
Old   August 30, 2016, 15:36
Default Mesh generation
Samraj Manickam Palvannan
samraj is on a distinguished road
Hello all, I have some problems generating mesh for the attached picture. Its a flow simulation model. two inlets flow into a nozzle and the flow out through outlet. The gas from 2nd inlet flows around the 1st inlet and by the exit of 1st inlet, the gas from 2nd inlet mixes and flows out. I tried meshing but the gas from 2nd inlet dont just flow around 1st but just on the top the 1st inlet walls and move to right hand side of the model. Any help or guidance on how to approach the problem would really help me a lot. Thanks very much
samraj is offline   Reply With Quote
Old   September 7, 2016, 11:55
please check the mesh model attached. Compatible with ansys and ls dyna.
My problem is, fluid from one domain enters into another domain.
Here from small L shaped part, the flow is in -y direction( flow direction - vertical to horizontal position of geometry) and flows into main domain.
How do i connect these already created mesh elements in a way that solver knows it flows out into another domain.
Any guidance would mean a lot.
thanks
unstructured mesh generation with strictly constrained boundary in simple space goujl Mesh Generation & Pre-Processing 0 January 29, 2015 10:44
[ANSYS Meshing] Question about mesh generation learning lnk ANSYS Meshing & Geometry 2 July 7, 2012 06:45
ISAAC code mesh generation morteza08 Main CFD Forum 0 June 15, 2012 09:26
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
