Home > Forums > General Forums > Hardware
ECC memory correction
Old   September 29, 2021, 03:56
Default ECC memory correction
Cinek_Poland is on a distinguished road
Hi. I would like to ask, ecc memory correction is required to doing FEM simulations ? (mechanic, forming)
I read that for example Epyc motherboard support ECC memory so if I will install non-ecc memory in Epyc motherboard it will be works ?
Cinek_Poland is offline   Reply With Quote
Old   September 29, 2021, 05:29
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
No, won't work. Well you might get non-ECC memory to work if it is registered memory. But those are rare, and there is absolutely no reason whatsoever to use registered memory without ECC. It is best to take a look at which memory types your CPU and motherboard support, before you start evaluating whether you need ECC. More often than not, that decision is made for you.
tldr: only use reg ECC or LRDIMM with ECC for Epyc CPUs.
In general, you don't necessarily need ECC for anything. Memory without error checking and correction works just the same, as long as no errors occur.
Whether your application should only be used on a machine with ECC memory is a different story entirely. But it's a rabbit hole you don't need to go down if the platform of choice is incompatible with "unbuffered" memory anyway. In which case you just get reg ECC RAM and start computing.
flotus1 is offline   Reply With Quote
Old   October 3, 2021, 06:43
Thank you for your answer.
General recommendations for CFD hardware [WIP] flotus1 Hardware 19 February 29, 2024 12:48
Used Memory Accumulates During Course of Simulation Until interFoam gets Killed Ship Designer OpenFOAM Running, Solving & CFD 7 October 6, 2023 01:26
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 05:40
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 06:33
ECC Memory Needed for Clusters? Jonas Larsson Main CFD Forum 1 January 17, 2001 08:08
