January 13, 2011, 13:57 |
Slow CFD
Adrian Dunne
I am a final year Mech. Eng. student performing CFD simulations for my thesis. I am running several versions of a 2D simulation. They are transient and are each taking about 24 hours to solve. My issue is that, when I look at my computer's performance while running the solver, I can see that only half of the RAM is operating. The solver is taking up over 500MB of RAM, but I'd like it to be able to take up more, to improve computation time. I know it's not an issue with a slow CPU, as this is running between 50% and 70%. I use 32-bit architecture, 667Hz and 4GB RAM. I would appreciate any suggestions on how i can improve compute time. Thanks. |
January 15, 2011, 04:52 |
Shishir
generally limiting the number of process running in the background and using a larger pagefile size should help speed things
but it still depends on the speed/core of your processor...faster the speed less computational time |
January 15, 2011, 06:43 |
Adrian Dunne
I get what you're saying, but the issue isn't really with trying to procure available memory, it's more to do with the fact that the CPU and RAM are only running at about 50% of their full capacity when running CFD. I want to be able to get the program to take up more RAM and CPU.
January 15, 2011, 21:12 |
Vieri Abolaffio
wich operative system are you using?
wich is the size of the mesh? are you using multicore paralleling? |
January 15, 2011, 23:46 |
#5 | |
Real Name :)
Sounds like you're not running parallel. Fluent will grind your machine to a halt, both in terms of RAM and CPU, if you're giving it the necessary resources. Additionally, 32-bit windows can only address 2 GB of the available (almost) 4 gb of RAM, unless the /3GB switch is used in the Boot.ini file.
See the following: http://www.microsoft.com/whdc/system...ae/paemem.mspx for more info. ComputerGuy Quote:
January 16, 2011, 05:47 |
#6 | |
Adrian Dunne
The mesh is generally around 200,000-300,000 nodes. I'm actually doing the simulations on my own HP pavillion laptop, it has only a single-core processor. |
January 20, 2011, 16:40 |
Dave
In answer to your question, the operating system would be the overarching system your computer is using. Examples would include windows (xp, vista, 7, etc), Linux operating systems like Debian, Ubuntu, Fedora. It sounds like you are using windows if you are using CFX on single core. As an aside I have found that when programs try and exceed the memory usage limit of a 32 bit windows OS, it tends to crash the program or windows.
January 28, 2011, 20:23 |
#8 | |
Consider reading up on the various settings you can set just before starting the simulation in xref.pdf or xmod.pdf or the like in the ANSYS directory (not in the most logical location). Another thing to check when running CFX is whether you have a process running called java.exe (via task manager). On our machines at uni (dual core) this process would sit in the background (generated via CFX to run the news updates I think) and gobble around 50% of the total CPU power of the machine. Killing this process off had no ill effect other than making a lot more processing power available. |
January 29, 2011, 09:15 |
Adrian Dunne
That explains it.
Thanks man. |
Slow speed CFD | Eric Strom | FLUENT | 0 | February 25, 2009 16:53 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
Since Last June | John C. Chien | Main CFD Forum | 3 | July 12, 1999 09:38 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
