November 2, 2005, 09:03 |
continuous function for wall-law
Do you know any continuous function for "fluid" wall-law covering viscous sub-layer and logarithmic zone at the same time ? (like Kader's law, for temperature) Patrick |
November 2, 2005, 10:23 |
Re: continuous function for wall-law
From my understanding, FLUENT's Enhanced Wall Treatment blends a two-zonal model with an enhanced wall function. The enhanced wall function used there is a continuous wall law, obtained by blending the viscous sublayer and log-law regions. The exact details are in the FLUENT manual (look under the section on enhanced wall treatment), but essentially it's just a simple blending function.
Hope that helps, Brian |
November 2, 2005, 11:27 |
Thanks you very much....this is exactly what I was looking for Yours, Patrick
November 2, 2005, 13:20 |
Tsan-Hsing Shih et al 2003 J. Turbulence 4 015
Application of generalized wall function for complex turbulent flows http://www.iop.org/EJ/abstract/1468-5248/4/1/015/ "... generalized wall function is extended to the whole surface layer (or inner layer), covering the viscous sublayer, buffer layer and inertial sublayer; therefore, it is a unified wall function." |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
